Since the new autofocus algorithm was implemented and I unknowingly updated my SGP, it became super frustrating to use it. It fails almost every time, and I have to rerun AF multiple times until it hits that arbitrary magical 90% fit. Why can’t I adjust that number? what’s wrong with 89% and why does it fail? Can I revert back to the old algorithm without reverting whole SGP?
Moonlite focuser, Skywatcher Explorer 250PDS, SX694-Trius
I may be wrong but with an exposure time of just 2 sec’s your going to be hard pushed to get any success at all, try pushing up your exposure time to around 6 sec’s and see what you get then.
There is a great tutorial in the SGP Help file regarding autofocus, specifically a formula to determine a good ballpark step size (I think yours may be too small as well as your exposure length). I followed the instructions there and have consistently achieved a good V-shaped curve and an accurate focus setting.
Try increasing your step size. I had similar troubles when the new algo was introduced and tried relaxing the quality threshold which helped a bit but in the end I doubled the step size and now get a good parabolic fit every time.
Yeah, I get excellent results on my SCT using 7 steps but a step size of 80 and using L primarily with an exposure of 2sec. I would think that a step size of 11 is too small for pretty much any focuser. I get it that it worked before, but you had to be on the edge and dependent more on the star quality and number in the FOV. Use a higher step size (dependent upon your focuser) and reduce the steps to 9 or 7 and you’ll get better results. Additionally, enable backlash compensation if not already done.
